clutch problem? - FirebirdV6.com/CamaroV6.com Message Board
clutch problem?
  • clutch problem?
    i was creeping the 00 up my friends driveway to drop him off (only laying off the cluth). a nasty loud noise appeared and the car was struggling a lil more than usual up that steep driveway. when i was driving home anytime i went below 2k rpm that noise would come up.
    i think it may be the clutch because before dropping off my friend, i got into a battle with a tiburon and a s40. i DC 5-4-3 to catch up to them after highbeaming each one until they understood i wanted to race them both. we cruised at 50mph. on the 2nd honk i decided to DC to 2nd, but i reved a lil under than what i was supposed to (not the 1st time), and when we took off, my SES light blinked for a few seconds then stopped. after the race we saw a cop up ahead, so i got off the nxt exit into a gas station, (my friend and i need to use the restroom) and left the car running. when we left, everything seemed normal. then i dropped him off and thats when the noise 1st happend
    any ideas what it could be?
    Re: clutch problem?
    is the car louder? is she running the same? more slugish? might have blown out the cat.
    WAWA-A-HOLIC
      Re: clutch problem?
      nothing seems wrong above 2k rpm.i drove to work this morning (less than a 5 min drive) and the sound that is made is an inconsistant griding sound. it def. does not sound like gear grinding, its much louder and diffrent sound. from a complete stop, in 1st rear, and i start to lay off the clutch, it does not have that same pull the car normally has. after work, i will be going to ikea with my friend ( a good 20 mile drive + few lights/stops) i'll take my camara and record that way you can get a better idea of what im try to describe (forgot my camera did that c(=)
        Re: clutch problem?
        so wen i went out to lunch, i thought about what you said, and in the lot, i kept the car in nuteral and lightly reved it, i could hear that noise. when i was driving, and paid attention to the noise, the sound was sort of familar to a small grindy sound my 3.4 makes, so i think you may be right. i tried pushing the car a lil hard, and it did seem a bit slugish.
          Re: clutch problem?
          def. sounds like a clutch problem, i used to do a lot of what your doing
          b4 my first clutch went out, i lost my second gear bark, and it was slower than usual, even after an oil change and i couldnt figure out why... i got the new one installed and after 500 miles i floored it and about got sideways in second ( this helps if u hav posi btw )
          clutches can make or break ur car
            Re: clutch problem?
            how many miles do you have on your car? the stock clutch is good for a pretty long time
              Re: clutch problem?
              103k. yesterday, i asked one of my friends, and he said it sounded like it could possibly be something in my exhaust, maybe just something loose.
                Re: clutch problem?
                yeah i have heard stories that the stock cluch lasting really really long time, so i really dont think it's your clutch
                  Re: clutch problem?
                  my stock clutch lasted 155k... who knows how long the new one will last, even if it will
                    Re: clutch problem?
                    i am uploading the clips, but the are taking forever
