Shift Points and Rev Limiter - FirebirdV6.com/CamaroV6.com Message Board
  • Shift Points and Rev Limiter
    OK, I've got a M5 97 Camaro. I've finally decided what I'm doing to it. GT2 cam, P&P Heads, Intense MLS Head Gaskets (+.1 compression, woot), new Oil Pan (mine's crushed), new gaskets just about everywhere, etc. What should I raise the rev limiter to, and what would be a good range to shift? I'll be getting it dynotuned abit afterwards to adjust everything, and am just wondering what range you guys would recommend
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Shift Points and Rev Limiter
    zzp should list the power ban of that cam, I would imagine 6400-6700 would be your max power band.
      obviously you know you are going to need new valve springs, retainers, etc etc.
        Of course. I'm looking into some 90#, or even 105#. I'll check ZZP's site.
        ~97 3.8L V6 Camaro~
        A few things
          I was reading on ZZP's site, and here's what they suggest: 7K Limiter and 6.5 shifts. Just wondering what you guys recommend.
          ~97 3.8L V6 Camaro~
          A few things
            I would go with 105's and they are pretty dead on with their rpm range, I would definietly not go any higher than 7,000 rpms for your rev limiter.
              k, thanks man.
              ~97 3.8L V6 Camaro~
              A few things
