im pretty sure they are the same, but i just want to make sure.. are the automatic and manual harness's of the 3800 the same?
automatic and manual mainframes?
Re: automatic and manual mainframes?
They are sligtly different. My car has been swapped out for a manual, and it did not have the proper connector for the reverse light switch.Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
Black/Red '02 Honda CBR 954RR Fireblade
i was told that too... buuut like i was told that if you plug the harness into a computer thats flashed for m5, then you will have no problem.
thats what im having done, the stock m5 computer on the camaro is whats being used.WE CAN REBUILD IT, WE HAVE THE TECHNOLOGY
my car has an auto pcm/harness with a manual trans if that helps.
the part that usally connects to the transmission is just pushed to the side
