automatic and manual mainframes? - FirebirdV6.com/CamaroV6.com Message Board
  • automatic and manual mainframes?
    im pretty sure they are the same, but i just want to make sure.. are the automatic and manual harness's of the 3800 the same?
    WE CAN REBUILD IT, WE HAVE THE TECHNOLOGY
    Re: automatic and manual mainframes?
    hell i just wish i knew what a mainframe was.
    1999 Firebird Y87/W68
      by mainframe.. i mean harness
        im pretty sure that they r differnt
        87 Firebird RIP
        96 Camaro RS RIP
        94 Patriot Red 1LE Z28 - Sold
        02 WS6 TA - Sold
          i would assume they are a tiny bit different, i mean, you cant control an automatic transmission with a manual transmission harness, its not going to have the wires necesary
            They are sligtly different. My car has been swapped out for a manual, and it did not have the proper connector for the reverse light switch.
            Representin' Team Red In The North
            Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
            Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
            Black/Red '02 Honda CBR 954RR Fireblade
              i was told that too... buuut like i was told that if you plug the harness into a computer thats flashed for m5, then you will have no problem.
              thats what im having done, the stock m5 computer on the camaro is whats being used.
                wtf r u doin again? r u using a auto harness on a manual or the other way around?
                87 Firebird RIP
                96 Camaro RS RIP
                02 WS6 TA - Sold
                  auto harness, manual cpu and tranny
                    the auto harness isnt gonna plug into the manual tranny....if u flash a auto pcm to manual one then ya the pcm will work but still the harness wont
                    87 Firebird RIP
                    96 Camaro RS RIP
                    02 WS6 TA - Sold
                      my car has an auto pcm/harness with a manual trans if that helps.
                      the part that usally connects to the transmission is just pushed to the side
                        moving to drivetrain.
                        Follow me!
                        Or this
                          i called the mechanic.. its all good.. automatic harness plugs right into the manual pcm no problem :P
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
