I want to know something, when upgrading the differential, from a non-LSD 3.08 (series 2) to a LSD 3.42 (series 3), is it a MUST to change the differential cover or is it possible to use the stock cover???
Differential Upgrade - Cover
Re: Differential Upgrade - Cover
Other thing I wanted to ask.
in my case, upgrading the differential, from a non-LSD 3.08 (series 2) to a LSD 3.42 (series 3), is it necessary to use the ABS Reluctor Ring that SLP sells and in which part of the differential setup the reluctor ring goes???
Originally posted by Smoke Pantherno, you can use the same ABS ring.
you're saying then, that my stock differential (non-LSD 3.08) has that ring, and it can be used on a LSD 3.42 upgrade?
Depends on what year your car is? If it has the ABS ring I believe 98' and up have it. Don't take my word fot it though, Let someone else post who has more info., I'm sure FirebirdGT would know.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by jbmetalyou're saying then, that my stock differential (non-LSD 3.08) has that ring, and it can be used on a LSD 3.42 upgrade?
Originally posted by Smoke Pantheryes. The ABS ring goes around the edge of the differential, and all f-body differentials, be they 2- or 3- series, are the same diameter08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411See I knew someone would know, I didn't know that. Thanks Smoke Pather, Good info. I thought I only had ABS on my fronts.
I hope to get it all installed by christmas.
so then is not necessary to buy it, and install the differential with a new reluctor ring. well, that'll be less thing for me to buy, since I will buy new bearings and everything.
Originally posted by Smoke Panther View Postyes. The ABS ring goes around the edge of the differential, and all f-body differentials, be they 2- or 3- series, are the same diameter
thank you people
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...14 hours ago
