so its been making a little sound for a while now but as soon as i got home it locked up going into my drive way...lucky ..i know...im not sure what to do....do it myself or have somebody do it ...or what messed it up in the first place...does any body have suggestions ??
hmm rear end locked up ...help!?
Re: hmm rear end locked up ...help!?
Originally posted by JDavilaok so i found out im gonna need a differential not the shafts or ring and pinion...where is a good place or web site to get one at?
What was causing the rear to lock up? Did you inspect every tooth on the ring gear?
Briansigpic
im learning parts as i follow up an do research on this....so give me a break on labeling the parts actual name... but the spider gearing shaft was broke and was causing the spider gears to lock up... the retaining bolt that holds the pin in is gone ... and the holes for the shaft is hollowed out so the differential carrier need to be replaced and the spider grears need to be replaced....if im wrong please correct me.. but i believe on what im reading.. im comming up with we have 28 splines for our shafts? because im seeing places that have 26 28 and 30... but im seeing 28 for a 99 camaro... just want to make sure
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
