does anyone know the metric specifications of the 8 flywheel to crankshaft bolts? their not in the diagrams manual and i need to know
flywheel bolts
Re: flywheel bolts
yeah im just bumping this up in case anyone every searches for this, but the bolts are 5/16 X 18... has to be in US size because there inst an exact metric size that would fit.1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Re: flywheel bolts
pull one of the other bolts out and go to a hardware store and find a nut that it threads into and youve got youre thread and pitch, if the markings on the heads are 8.9 10.9 12.9 etc they are metric if they are slash marks they are standard
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Re: flywheel bolts
Originally posted by 99 Camaro SuperSixI believe that they are 1/2 or 9/16. but watch out when you tighten them up they do not take much torque to break, 40 ft lbs is the max I would put on them. they will break at 42 or so.
Re: flywheel bolts
you can go to the dealer and get the right bolts, it will cost a little bit more but they will be the factory bolts
item #24505092
Re: flywheel bolts
Originally posted by Meatyshellsyou can go to the dealer and get the right bolts, it will cost a little bit more but they will be the factory bolts
item #24505092
good call on that
Re: flywheel bolts
Originally posted by 99 Camaro SuperSixthat is what I did and they will cost about 4.00 a bolt and they only come packs of 5.
yeah same thing happened to me, i ordered a pack from gmpartsdirect.com and i figured a pack would be 8 since thats how many you need, but nope its 5. on top of that they have to special ordered and it took almost a month to get it to me. so f that1999 v6 Camaro M5
Re: flywheel bolts
go to a fastener store, a store that just sells nuts, bolts, and other assorted fasteners they will be able to help you out
