1le Tranny mount - FirebirdV6.com/CamaroV6.com Message Board
1le Tranny mount
  • 1le Tranny mount
    I read the sticky, i'm just wondering, is the 1le tranny mount the same between autos and manuals.
    I'm swapping a new auto into my car and I want the 1le tranny mount and corvette servo. I've never even heard of a 1le automatic before so I want to make sure I dont get the wrong part.
    Do I have anything to worry about?
    Mystic Teal Metallic
    Re: 1le Tranny mount
    they are the same
      What is the gain to install the 1LE or LS1 tranny mount? Any difference?
      thx for help
        Fvck all that. Instead of blowing 50 bucks on a hydraulic mount, we used the tranny mount from a 92 Camaro. It's a little rubber and metal thing and it bolted right in. I'd say it was definitely worth it. ~$10 for the 3rd gen transmission mount > $50 for the hydraulic mount.
        I'm pretty sure this is the one we used.
        Originally posted by LETZRIDE
        I've never touched a rear end before
          that looks just like the 1le mount haha. but idk i had problems with my 1le mount. The mount had too much play in it and was causing my shifter to bounce on hard acceleration. So i switched to the poly mount and its not bad at all
            yeah, i believe it is the same mount if you look at the vehicles that it fits i believe it says it fits the v8's
              thx for help
              so do T56 tranny mounts work for the T5 as well? would this poly mount work for the T5 http://www.ws6project.com/user_stor/...0ae995e1ee8a1c
              1999 Firebird Y87/W68
                i just got done putting in the mount about 5 minutes ago and went around and took it for a spin and its nice...only complaint is that you feel a little more vibration than normal but its much better than a ridiculous bouncy shifter and bumping and grinding noise .i used the stock v8 mount and it worked great and its only $10 from advanced auto.
                  2 days ago
                • 187shark
                  by 187shark
                • Doodler
                  97 Camaro base with expensive sounding noises
                  by Doodler
                  Still trying to find oil leak
