6 Speed Swap possible? - FirebirdV6.com/CamaroV6.com Message Board
  • 6 Speed Swap possible?
    Is it possible to swap a 6 speed from a ls1/lt1 onto our v6 (specifically a 3.4) cars?? I'm not sure what engine I want to do (or can afford it right now) but want to swap over to the six if it is possible?? Thanks
    Re: 6 Speed Swap possible?
    It is now but it is very $$$$ last I saw you need a core t-56 plus $2600 from six speeds inc at
    http://0174de9.netsolstores.com/
    This is all the info you can get.
    http://www.fullthrottlev6.com/forums...ad.php?t=34157
      you can get them for $1000 on ebay
        why would you want a 6 speed on a 3.4? your not gunna have enough torque to push through 1st.... :tdown:
        1999 v6 Camaro M5
        Automatic to Manual converted
        Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
        !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
          I put one in 3.8
          http://forum.camarov6.com/showthread...997#post816997
          Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
