Broke my 7th T-5 today and im sick of it.... For those of you that have G-forces what ratios do you have? and is there any cheaper place to get the gear set I can install it myself.
G-Force ratio?
Re: G-Force ratio?
Originally posted by coolbet13Broke my 7th T-5 today and im sick of it.... For those of you that have G-forces what ratios do you have? and is there any cheaper place to get the gear set I can install it myself.
7??!:(1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Re: G-Force ratio?
so I'm gonna have to get a different rear gear to make up for the trans differences? 4.11 or 4.56 which would be better? think I remember hearing something about the speed doesn't work with the g-force whats that about?
Re: G-Force ratio?
Originally posted by IDoVoodooThese are their synchronized ratios.
2.94, 1.94, 1.34, 1.00, and .59 or .73 5th gear
You'd probably want a .59 5th since you're probably gonna need 4.56 gears.Old Car = 12.679 @ 106.5 on 150 dry shot.
New Car = 2010 3.6l 304hp Camaro
Re: G-Force ratio?
you have 2 options with the speedo and G-force build.
The worm gear reader needs to be relocated by drilling a new hole (needs to be nearly perfectly drilled) into the sid of the tranny.
second you could hook up your speedo to the driverside wheel sensor. This means you'll loos ABS.
Sorry 3 options: You could just do without a speedo.Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
