Wtf...? - FirebirdV6.com/CamaroV6.com Message Board
Wtf...?
  • Wtf...?
    somethings been bothering me now for a while, because when i got my car painted on the estimate was the vin number and some of the options on my car, and it said 5 speed manual transmission. Well my car is an automatic. so i finally checked the door codes and sure enough, my car started out its life as a 5 speed. which is kinda scary to me. cause who in their right mind would swap a 5 speed for an automatic? and now that i've figured this out that brings up some other questions, i kno my car originally had the y87 package. but since they switched transmission before i ever had it i wonder what else is different.
    So basically my question is how can i tell what kind of differential i have, and what rear end gear i have, WITHOUT opening anything up or taking it apart?
    Re: Wtf...?
    rotating the tires while the car is ona jackstand
      Re: Wtf...?
      what do u mean?
        Re: Wtf...?
        jack the rear end up letting the rear tires hang freely spin a wheel, if the other wheel spins with it = posi
        you can check your gears by seeing what your rpm:speed ratio
        like if you are at 2500 rpms at 84 is 3:23 with 40/17 tires
          Re: Wtf...?
          Or you can just count how many times the driveshaft turns over...if it turns over a little less than 3 and a half times, you have 3.42s. If it turns a tiny bit more than 3 times over, you have 3.08s. If it turns over 3 and about a quarter times, it has 3.23s
            Re: Wtf...?
            Did you check the VIN on the door against the VIN in the windshield? Someone might have changed the door.
              Re: Wtf...?
              there should be an id tag on the rear end. or on one of the axle shafts right next to the rear end. i looked mine up before i ordered parts to rebuild a long time ago. my tag was hard to read.
                Re: Wtf...?
                That print out that the body shop gave you simply lists standard equiptment. When i had the body of my car worked on the print out was the same way.
                Daily: '02 Black Yukon Denali
                Toy: '06 Torrid Red GTO
                Gone: '07 Charcoal Yamaha R6
                Gone: Ex-wife, lol
                  Re: Wtf...?
                  +1 My driver's door says I own a Trans Am :drool:
                  2001 Pewter Firebird Y87, M5
                  Go Sabres!
                    Re: Wtf...?
                    I'd peal that sticker.
                      Re: Wtf...?
                      FYI my VIN comes out the same way. And I know from day one this car has been an auto! All that print out is; your car, year, and standard equipment. (which is a manual)
                      Read your door codes, and thats what you have...
                      BTW; Best title ever :D
                      98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
                        Re: Wtf...?
                        the threadstarter already checked the door codes, and it says his car has the t5 in it
                          Re: Wtf...?
                          mine gets pulled up as a z28 with the v6 option
                          1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
                            Re: Wtf...?
                            So does mine....
                              Re: Wtf...?
                              my car's codes say i have an auto :D
