Stall converter? - FirebirdV6.com/CamaroV6.com Message Board
Stall converter?
  • Stall converter?
    what would be a good stall converter for an 02 chevy camaro v6, would one for an ls1 work if not were can i find one?
    Thanks, also how many splines is a factory torque converter for our cars?
    Re: Stall converter?
    you can fined them everywhere, as to the splines i don't know. what i have found is that i can do my a4 to m5 conversion cheaper than buying a stall for our cars.
      Check out abbott racing, also check out the modification encyclopedia for a few companies. Its according to what you do to your car that determines what size stall you have. so look into what perforamnce mods you watn to do to your car before purchasing one. if its a stock car, no use changing it IMO, cause if you do upgrades and decide to go bigger, you have to take the trans down again, do it once, do it right I say. Oh, and no LS1's wont fit, just V^ versions will.
        an ls1 one cannot be used.
        look at getting a 3000 or a 3500 stall from abbott racing, herron performance, or performabuilt
        http://www.bowtiev6.com/
          I would say if not modded that much 3000, modded 3500.
            In are N/A car we tried alot of diffrent ones best one was the 4,500 stall. We sell them for $800. LS1 is 30 spline, v6 is a 28 spline.
              people on this board seem to just buy converters at random. you have to have you car on the dyno and look at the torque curve to see what you want.
                What you want usually isn't what will work best in the car. Sometimes you have to go with less stall to keep it drivable.
