stuck in 1st - FirebirdV6.com/CamaroV6.com Message Board
stuck in 1st
  • stuck in 1st
    ok i have a 95 firebird with the 4l60e, the tranny is locked in first gear or so have i bin told by the trans shop.
    this is what it is doing.
    P = no free revs:(
    R = nothing just sits there :rant:
    N = first
    D = drive seems to work fine
    3 = works fine
    2 = works fine
    1 = works fine
    neutral and first are the same now what the shop told me is that the first gear clutches are welded(welded themselves up), i haven't ever really pushed the car all the hard it just did this one day with no warning. if first is locked up is there a way to unlock it so i get neutral back and park? any help would be great or any other ideas, i am planing on doing a manual swap but need more time to get everything together to do it and i hate having to park out in the boon docks win i go some where just so i can pull strait out.:rant:
    Re: stuck in 1st
    tranny rebuild time.
      Re: stuck in 1st
      not for what they want, to much money i will do a manual swap first for less than doing the rebuild.
        Re: stuck in 1st
        Dealership? 3000+
        Even a reputable trans place will be 1800+
        My thoughts on a manual, yeah they're fun but why row the boat when you can get a motor for it.
          Re: stuck in 1st
          i have a manual for it just need the rest of the stuff. and i dont have 2000 to spend on a rebuild or a new trans.
            Re: stuck in 1st
            Was the trans fluid burnt before this happened?
              Re: stuck in 1st
              no the trans fluid is clean and looks good and no burnt smell. the car drove fine and had revers, i got up one morning and no revers and neutral is first.
                Re: stuck in 1st
                Sounds like something hung the piston up in the low gear drum.
                  Re: stuck in 1st
                  is there an easy way to fix that??
                    Re: stuck in 1st
                    Not with out removing the trans and disassembling it.
                      Re: stuck in 1st
                      ok that sucks, could it be something in the valve body?
                        Re: stuck in 1st
                        Could be.
                          Re: stuck in 1st
                          is there a way to check to see if its one or the other.
                            Re: stuck in 1st
                            Disassemble it. It's more likely a ring leaking and engaging the clutch pack.
                              Re: stuck in 1st
                              ok, that sucks. well i guess if any one wants a 4l60e and ECM. i will let them figure it out i just didn't want to put much time into the tranny since i am planing on doing the manual conversion.
                              • Manimal
                                Coil springs
                                by Manimal
                                6 days ago
                              • Manimal
                                Newby here
                                by Manimal
