clutch questions - FirebirdV6.com/CamaroV6.com Message Board
clutch questions
  • clutch questions
    Im doing a new clutch myself and need to know what all do I need to buy?
    may sound dumb but can someone just give me a list of things I need to replace for a new clutch.
    also. Ive heard alot of different things about different clutches. for instance, specs chatter or whatever. anyone got a suggestion for a good racing clutch. nothing above a stage 2 cuz I cant afford it and dont need it.
    so help?
    Re: clutch questions
    just to be safe you should do your slave and master. t.o bearing too. when you get in there check out your fly wheel. you might want to get that cut.
    as for clutchs.....how much hp do you have?
    WAWA-A-HOLIC
      you should definitely have your flywheel resurfaced. Make sure you clean it with brake klean after you install it. might as well replace the pilot bearing as well
      69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
