Prothane master kit tranny mount question - FirebirdV6.com/CamaroV6.com Message Board
  • Prothane master kit tranny mount question
    I have a 1994 3.4 camaro and just did the rear end swap with a 1994 camaro Z28 with disc brakes. I am going to be doing the poly bushings with prothanes master kit (part # 7-2009). I have heard that there is a problem with the tranny mount in that the trans will sit 1/2" lower causing vibration hence needing a spacer. Is this true? I have also heard that if you use a crossmember from a LT1 it is now a direct fit. Is this true? Thanks for any help.
    Re: Prothane master kit tranny mount question
    i have heard something about using a spacer but not on the Lt1 cross member.
      it's in the stickies up top :)
        Yes, I just saw the sticky but was wondering if the prothane mount was the same size as the 1LE.
          yup, that's posted in the sticky as well
