my poor clutch has had it - FirebirdV6.com/CamaroV6.com Message Board
  • my poor clutch has had it
    decided to let my car see 3500+ rpms today, right when it hit around 4500 the clutch started slipping
    only reasonable thought is the clutch cant handle the power it is making at that rpm
    time for a new one i guess, and i still have no idea what brand i want, everyone seems to have horror stories about each type
    Re: my poor clutch has had it
    i have nothing bad to say about centerforce dual friction. my car is putting 336 rwhp and 412 rwt to the ground. it holds it very well.:banana:
    WAWA-A-HOLIC
      does centerforce make stock like clutches?
      with my low amount of stock HP, i dont think i need anything too extreme, if oyu know what i mean
      does it act/feel like stock?
        so is centerforce the way to go?
        how are zoom clutches?
        edit* what about perfection clutches? advance auto has a complete kit for under $300
          anyone??
          i want to buy a clutch very soon, as im putting it in next month
            Why not just buy a stock replacement clutch. Is there anything wrong with them?
              because i dont know what type of clutches GM uses, and they are probably much more expensive than an after market one
              i ALWAYS use the stock parts GM puts on their cars, but a clutch is probably gonna be a bit too expensive
                go to autozone and buy a clutch, problem solved
                  i would, but im sure they offer like 4 different bands, and i dont know which one to pick, which is why i asked in this thread.
                  i do not want to get a piece of crap clutch that will wear out or give me problems in 5000 miles
                  i put cheap rotors on my car, and they were warped within 1000 miles.. horrible
                    oem clutches are all one in the same
                      You got a stock clutch Meaty?
                      Lounge Moderator
                        yeah, i actually took my spec clutch back out and replaced it with an oem clutch
                          what brand is it?
                            what ever they had at autozone was around $200
                              and it's holding your 600 HP?
                              Lounge Moderator
