burnout then wheel hoping? - FirebirdV6.com/CamaroV6.com Message Board
  • burnout then wheel hoping?
    ok so today i went up to a stop sign then held my foot on the brake and did a brake stand but then when i release it felted liek my rear end of the car was just jumping like hoping up and down and it sounded really bad ???? Is it the rear end? then i tgired againg same problem ? anybody kno
    Re: burnout then wheel hoping?
    Well the cars not meant for this but I'd say you need to replace your stock rear suspension. How many miles are on your car? Crawl under car and see if you see anything bent? Look for warn bushings. May start with new LCA and relocation brackets
    Originally posted by kala
    I'll have buttsecks with Richard Simmons!
    TEAM BLACK!!!
    parting her out
      hooked on phonics???
      my other truck has a 50 cal mounted on it
        Didn't work for him :P
        It's called wheel hop. LCAs usually clear it up.
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          Or new lca bushings, or shocks.
          1996 Chevrolet Camaro
          1995 Buick Park Avenue Ultra
          --Appearance Moderator--
            wait, what happened exactly, im not following this hoping business
              ok when i do a burn out it sounds like a big knocking nosie and it stops spinning the wheels i got 56k on the car
                traction control?
                  don't know if TCS would cause the knocking noise but i'd def. take a hard look at your rear suspension... sounds like wheel hop to me.
                  Y87 Package
                  MANUAL CONVERTED, Pro 5.0 Shifter
                  Pacesetters, Magnaflow Cat, Cutout, Flowmaster
                  MOGOB APPROVED!
                  BONE APPROVED!
                  VANBIBBER APPROVED!
                  KRISTEN APPROVED!
                  Vice Prez.
                  Team Black...TEAM EMO
                  Come on kids! Get a Calendar!
                    TCS there is no optiion on my car to turn it on or off is there I dont have any button for it
                      wheel hop. had same problem. Happened when i went to larger rims. LCA's should fix it. :) /end thread
                      1998 Red T-top V6 Camaro
                      - K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
                        My car is a wheel hoppin', tranny mount breakin' bee eye itch. I'm installing the LCA's and relocation brackets Wednesday. I'll tell you if they fix the problem.
                        Lounge Moderator
                          No, you can't turn TCS off, it's built into the rear, and this more than likely isn't TCS...you just need new Lower Control Arms.
                          Y87 Package
                          MOGOB APPROVED!
                          BONE APPROVED!
                          VANBIBBER APPROVED!
                          KRISTEN APPROVED!
                          Vice Prez.
                            thanks guys when i get more money i guess where can i find them for a good deal?
                            • 187shark
                              by 187shark
