Is the y87 rear end the exact same as what they used on the Z28's? I have a 96 v6 A4 rear disk brakes with the y87 package. Im doing an LT1 swap. I want to know if I will need to swap my rear end? Is it the same rear end they put on the 96 z28's ? I did a search, but I got conflicting answers. Thanks guys.
y87 rear end the same as the z28?
Re: y87 rear end the same as the z28?
Being that you have an A4, you should have 3.42 gears. GU6 option code in your counsel. You would need to have the PCM programmed for that gear ratio. I'd use the axle after the swap.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Originally posted by Bird_Of_Prey View PostBeing that you have an A4, you should have 3.42 gears. GU6 option code in your counsel. You would need to have the PCM programmed for that gear ratio. I'd use the axle after the swap.
Shhhh.... You have much to learn young n00blet. No 4th gen f-body EVER came from Ste. Therese with a numerically higher gear ratio than 3.42. Do a search, and you'll see.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Originally posted by mrhobbz View Postthe Y87 package comes out of the factory with 3.73's.
As for the question, I don't think it's the exact same rear but it very well could be. In 1996 y87 camaro's and firebird's came with Auburn LSD's and 3.42's in a GM 10-bolt. So to answer the question, the rear you have now should be more than enough for an LT1.Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Originally posted by Firebirdkid96 View PostBull ****. The y87 package comes with 3.42 gears in an A4 car and 3.08's in a T5. GM would never put 3.73 gears in a production model car, it's just not efficient.
Originally posted by bigbrian442 View PostReally??? What about the trucks that come with 4.10's then.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Originally posted by Firebirdkid96 View PostThat's a truck, not a sports car that they're trying to retain streetability in. You have more experience than I do, but I can't see GM putting 3.73's in a production model like the camaro or firebird. Maybe I'm wrongsigpic
So I'm wrong in my opinion on GM's production ideals. Big deal.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Originally posted by bigbrian442 View PostWhat's the difference? Trucks aren't driven on the street? You could order 4.88 and 5.13 gears in 12 bolts in Camaro's. And that was before they had overdrive!Let's flip a coin. Heads I get tail, Tails I get head.
Originally posted by Firebirdkid96 View PostThe y87 package comes with 3.42 gears in an A4 car and 3.08's in a T5.
And no, you won't need to swap the rear end.
my bad I knew that was wrong lolY87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...11 hours ago
