y87 rear end the same as the z28? - FirebirdV6.com/CamaroV6.com Message Board
  • y87 rear end the same as the z28?
    Is the y87 rear end the exact same as what they used on the Z28's? I have a 96 v6 A4 rear disk brakes with the y87 package. Im doing an LT1 swap. I want to know if I will need to swap my rear end? Is it the same rear end they put on the 96 z28's ? I did a search, but I got conflicting answers. Thanks guys.
    Re: y87 rear end the same as the z28?
    Being that you have an A4, you should have 3.42 gears. GU6 option code in your counsel. You would need to have the PCM programmed for that gear ratio. I'd use the axle after the swap.
      the Y87 package comes out of the factory with 3.73's.
        Shhhh.... You have much to learn young n00blet. No 4th gen f-body EVER came from Ste. Therese with a numerically higher gear ratio than 3.42. Do a search, and you'll see.
          Bull ****. The y87 package comes with 3.42 gears in an A4 car and 3.08's in a T5. GM would never put 3.73 gears in a production model car, it's just not efficient.
          As for the question, I don't think it's the exact same rear but it very well could be. In 1996 y87 camaro's and firebird's came with Auburn LSD's and 3.42's in a GM 10-bolt. So to answer the question, the rear you have now should be more than enough for an LT1.
          Y87 Package
          MANUAL CONVERTED, Pro 5.0 Shifter
          Pacesetters, Magnaflow Cat, Cutout, Flowmaster
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          Team Black...TEAM EMO
          Come on kids! Get a Calendar!
            Really??? What about the trucks that come with 4.10's then.
              Yeah, mine has 3.42 gears. Good, I was hoping I wouldnt have to change it out. My buddy was trying to get me to look for a posi rearend. My car will have minor mods, but nothing heavy like Nos or a super charger.
                That's a truck, not a sports car that they're trying to retain streetability in. You have more experience than I do, but I can't see GM putting 3.73's in a production model like the camaro or firebird. Maybe I'm wrong
                Y87 Package
                MOGOB APPROVED!
                BONE APPROVED!
                VANBIBBER APPROVED!
                KRISTEN APPROVED!
                Vice Prez.
                  What's the difference? Trucks aren't driven on the street? You could order 4.88 and 5.13 gears in 12 bolts in Camaro's. And that was before they had overdrive!
                    So I'm wrong in my opinion on GM's production ideals. Big deal.
                    Y87 Package
                    MOGOB APPROVED!
                    BONE APPROVED!
                    VANBIBBER APPROVED!
                    KRISTEN APPROVED!
                    Vice Prez.
                      You won't find those options available on any street car and very few truck options. With the aftermarket you can put anything you want in there. Does it make sense for a street app? Not at all.
                        No, you don't need to swap rear ends to do a LT1 swap
                          Actually 3.23s for the manuals.
                          And no, you won't need to swap the rear end.
                          1996 Chevrolet Camaro
                          1995 Buick Park Avenue Ultra
                          --Appearance Moderator--
                            my bad I knew that was wrong lol
                            Y87 Package
                            MOGOB APPROVED!
                            BONE APPROVED!
                            VANBIBBER APPROVED!
                            KRISTEN APPROVED!
                            Vice Prez.
                              all 4th gen camaros use the same rear end, just different setups (like LSD, different gears, etc)
