Rear end Q's - FirebirdV6.com/CamaroV6.com Message Board
Rear end Q's
  • Rear end Q's
    I have open 3.08's on my camaro, A friend of mine gave me a 3.42 ring and pinion towards getting 3.42's and posi...
    Was told that I will need a 3 series carrier? Does that mean the whole rear end housing or specific parts?
    I know nothing about rear ends so sorry if its a newb question.
    Edit: Read the FAQ, I now know the "carrier" is another name for posi, lsd etc... But is it the whole housing or just a part inside the housing is what I need to know now.
    Thanks.
    Re: Rear end Q's
    it is a part inside the housing
      Re: Rear end Q's
      and your going to do this yourself??
        Re: Rear end Q's
        So all I'd have to do is get the part(3 series carrier) And install it along with the 3.42 ring and pinion in the stock housing I have and be all set?
        Yeah why not? :D
          Re: Rear end Q's
          installing a carrier is something an amatuer could handle
          That's all the parts you'll need
          Yeah why not? :D
          Because the pinion needs to be set to within a thousandth of an inch, and any greivance in either direction will cause the gears to fail prematurely, causing thousands of dollars worth of damage....that's "why not"
            Re: Rear end Q's
            Haha, I was messing with that other guy... I got professional installation help for my rear end gear swap. :)
            Thanks for the info, smoke.
