Someone offered to sell me a aluminum driveshaft out of a 2002 Camaro SS, has the u-joints included. So just to double check...this WILL indeed fit my 1995 5-Speed 3.4 V6 right??? Also a link or instructions (preferably pics) of how to do this if it is possible would be great as I've never done this before. Thank you.
Just wanna double check...aluminum driveshaft Question
Re: Just wanna double check...aluminum driveshaft Question
yes, it will fit.
take off the "exhaust cross member"....it doesnt hold anything up, its just there, then unbolt the bolts on the yoke holding the driveshaft to the diff. after that, push the ds into the trans a little further, to get it out of the yoke. once the back half drops, pull it outta the trans. installation is the reverse of removal.Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Originally posted by kylerobison View Postno Fn way its that easy. i could do it in like 30min from the way that sounds. lol
just make sure the back end of your tranny is level or higher than the front of the tranny or your going to loose fluid when you pull the ds out
Thanks for the heads up on transmission fluid possibly leaking...don't want another incident to happen where someone told me how simple it was to replace the reverse switch. To my surprise I had to learn how to change the transmission fluid on a whim for a manual as the person didn't note that the fluid would come. So is there a way to do this will NO fluid coming out or will some come out? Also another person offered me one for really cheap but it has no yoke/u-joint so how much are those roughly? Thank you
Originally posted by TheGr8Schlotzky View PostIf you jack it up from the back, which I did, not a drop of tranny fluid will come out. It took me roughly 15-20 minutes including the time to jack the car up, which always takes forever with my crappy jack.
Originally posted by Firebird Phoenix View PostThanks for the heads up on transmission fluid possibly leaking...don't want another incident to happen where someone told me how simple it was to replace the reverse switch. To my surprise I had to learn how to change the transmission fluid on a whim for a manual as the person didn't note that the fluid would come. So is there a way to do this will NO fluid coming out or will some come out? Also another person offered me one for really cheap but it has no yoke/u-joint so how much are those roughly? Thank you
I just jacked up back enough for me to fit under my car, and had no problems. Took about 10 min. I would double check the bolts a few days later make sure no come loose.
when i changed my fuel filter i backed my car up on ramps and while i was under there i said to myself "man, it looks really easy to change my drive shaft, i wash i had one"
but yeah how much do they normaly cost? and how much of an upgrade is it over stock?
usually a hundred bucks, the upgrade is absolutely unmatchable. really reduces rotating weight so it gets alot more power to the diff.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Originally posted by savagecamaro96 View Postwhen i changed my fuel filter i backed my car up on ramps and while i was under there i said to myself "man, it looks really easy to change my drive shaft, i wash i had one"
