grr rear end noise... - FirebirdV6.com/CamaroV6.com Message Board
  • grr rear end noise...
    well my rear has been making noise since i put a auburn LSD in it i never changed the bearings it came with) so i ripped it out bought new bearings and cups changed it out added gm lube and valvoline 80w90 test drive sounds great no problems 300 miles later noise is back.. wtf! what is my problem?!?!?
    01 camaro
    3.8
    auburn LSD
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: grr rear end noise...
    well, did you re-shim it to match? just cause its the same unit doesnt mean that it will keep the gears aligned.... you probably have too much/not enough backspacing...
    when is it making noise? acceleration, or deceleration?
      Check to see if your pinon bolt has back out, they are TTY.
        it does it under acceleration what sould the stock play be side to side? and what about backlash on stock 3.42s? what are the stock specs?
        2001 Camaro 3.8 A4
        1991 3000GT VR4
          the specs are broad... like .008-.012. did you use stock shims? or re-shim the posi?
            i used the stock shims on my auburn after i replaced the bearings and caps on the carrier i had to drive the shim in with a rubber mallet it was so tight
            2001 Camaro 3.8 A4
            1991 3000GT VR4
