i have my backlash @ .006 gm said as long as its between .005 and .010 i am good my question is how much play should i have left and right i have .007 left and right (thats moving the whole carrier) my fear is that if i shim the carrier anymore its going to be too tight.. opinions?
question about seting up rear..
Re: question about seting up rear..
Originally posted by vr4gasm View Posti have my backlash @ .006 gm said as long as its between .005 and .010 i am good my question is how much play should i have left and right i have .007 left and right (thats moving the whole carrier) my fear is that if i shim the carrier anymore its going to be too tight.. opinions?sigpic
i just don't want to have to drive the shims in with a hammer or something to my knowladge its not supposed to be that tight but it would almost have to be to get no left to right play..2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
It SHOULD be that tight. There should definately be absolutely no movement side-to-side. You will have to tap the shims in. I usually use a brass punch and a hammer. The best way is to stack all the shims you'll use together and push them all in at the same time. That way you won't end up damaging any one individual shim.
There is actually a method to measure proper preload on the carrier bearings, but the easy way to get the proper preload (or very close to it) is to measure the thickness of the stock shims. Measure the thickness of each shim with a micrometer (measurements must be accurate!). Add the measurements together and write that number down as "total shim thickness." Measure the thickness of each of your new shims and separate them by thickness. I also find that it's best to write the thickness of each shim ON the shim with a marker. The thickness of all of the shims you use (both sides added together) must add up to be within a few thousandths of the total shim thickness you measured from the stock shims. As long as you do that, your carrier bearing preload should be within spec.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
