Throw-out bearing?? By "chattering" are you referring to a noise like a tapping or knocking sound? It only does it when the pedal is pushed in? Do you feel anything in the pedal?
-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Does it kind of sound like a rattling noise by chance? My car is doing the same thing, I always thought it was a heatshield somewhere. Maybe go thru again and make sure that you have tightened everything?
I'm still leaning towards a throwout bearing. Is it new?
I know a lot of race clutches chatter badly. My Centerforce did it loudly in Neutral, even when brad new. Its the nature of the beast in high performance clutch disc.
ok i drove it a bit more, it kinda changed (the sound, that is)...now it makes the sound when i accelerate and when shifting when moving....
the whole slave cylinder and bearing are brand new
(i basically installed a totally new clutch system : flywheel, clutch plate, pressure plate, throwout bearing, and slave cylinder)
the clutch is a Brute Power....its a company off of Zoom...this clutch should be stock...
also i can kind of hear it when in neutral...but a TINY TINY bit
again, i feel nothing in the pedal or shifter..i can only hear the sound..
i mean i can deal with the sound....but is it bad?:( lol
well it shouldnt be making a noise other than when you have the clutch pressed down
i would try to bleed it more, maybe try using a mityvac
