I think thats the same ones they sell at Thunder racing etc. You will most likely have to notched the crossmember to get it to fit but it is not a big deal. I ran my poly with my M5 and then when I did a M5 to A4 swap used it also. I would also use spacers or like I used rubber endlinks to adjust the height so your driveshaft sits where it is suppose to be, their should be a write up on the poly trans mount install.
thanks, i did see the writeup
that person installed the mount with that little bar, but mine is missing,so im not sure what to do..
I don't think I used that little bar on mine, I would have to look. I just looked at my cardomain and it looks like I didn't use a second bar, I probably didn't have one either, but the bushings make up for difference in height, my driveshaft is at Zero when I put a level on it. I haven't had any problems for 3-4 years and that's with a M5 and then swapping in a A4. I just have to tighten the bolts sometimes, because I will get a clunk when it is getting loose. I try to check them when I do oil changes. I think I'm going to use some locktight this next time to see if that works better.
