anyone no what the trans oil temp should be under normal conditions in a 97 A4??
trans oil temp
Re: trans oil temp
I know in AZ average is 180-210 in the hot summer. This is with no add-on tranny cooler.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: trans oil temp
The trans temp is probably always going to be in the 190-210 range bcause the trans fluid runs through the radiator, therefore keeping the trans at the same temp as engine... Unless for some reason the trans is under a heavy load that's heating it up.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: trans oil temp
Originally posted by Rob Bell View PostThe trans temp is probably always going to be in the 190-210 range bcause the trans fluid runs through the radiator, therefore keeping the trans at the same temp as engine... Unless for some reason the trans is under a heavy load that's heating it up.
The trans cooler is in the cold side of the radiator that is much cooler then the temps the temperature gauge or t stat see's.sigpic
Re: trans oil temp
This is why I run a B&M supercooler here in AZ and Valvoline Dexron VI synethic fuild becuase , I think dexron III starts breaking down around 250 degrees or something like that. On a hot day and beating on it in 115 degree temps and road temps 130+ , I would imagine a stock car would having its tranny fluid start turning black. The thing I like about the Dexron VI is it is clear like so when it getting darker I'll know when to change it.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...22 hours ago
