Ok guys I posted about my car not shifting into first until late. How long can these trannys last? I have almost 200000 miles. Should I try changing the fluid - which I have been told stinks - and filter and see if it helps? The more I drive it the less rpms it revs to shift...like I said in my other post I just bought it after it sat for 7 months.
If I look for one what should I look for? Used, rebuilt? Which tranny should I look for?
I have a 1993 Trans Am LT1...
Thanks everyone...
Robin
what i would DO if i were you.
(do not drive it anymore unless you drive it to a service shop.)
(if you wanna do it yourself.)
take a shop vac. pull your dipstick. put a funnel in your fill stock whole and hold the hose for the shop vac to the funnel, which will suck the tranny fluid out. AFTER its no longer sucking. (poor 5 cans of seafoam trans fix. or trans x.) both can be found at autozone. trans x is cheaper. for 5 cans of what you choose and a quart of synthetic tranny fluid.
after youve poured it all in there. turn the car on. and shift from p. r. d. (and then press your start in second button. which will engage the second gear when your in drive.)
after shifting from park reverse first second and neutral. for about 3-5 min.
pull the pan. filter. and replace the filter. then put the pan back on.
fill the trannny with (synthtic fluid) to the proper fill level. and drive down the road. easy in each gear.
btw. doing it yourself is gonna be about the same price comparred to taking it to a shop and having a FLUSHED. (but they do not replace the filter) or pull the pan. so doing it yourself is going to have better results.
The transmission shop (they only do trannys)I spoke to said they would pull the pan and see if there are any chuncks of metal to suggest failure. If not then they will check all seals and then replace the filter and gasket and put new fluid in....then check to make sure the cable is adjusted right
you might be able to fix it with a normal fluid change.. however do NOT get it flushed out, or drain all f the fluid and put seafoam or transx or whatever in there, i guarentee you that if you do that, you will have to get a new transmission
