Gear Codes in Glovebox? - FirebirdV6.com/CamaroV6.com Message Board
  • Gear Codes in Glovebox?
    I was reading the FAQ section and found this:
    To find out what gears you have look in your glove box and compare with the codes in the technical database.
    But when I look in and around my glove box (98 Firebird), I find no labels at all. Is there somewhere else the axle gear ratio is listed? I recall looking at the rear axle tubes on other GM cars to get the code. Same with the F-bodies?
    Re: Gear Codes in Glovebox?
    inside the door jam on the driver side
      RPO codes should tell you. Like he said above; on the door.
      Leonard
      www.fquick.com/96V6Junkie
        Ugg. You guys are right. I was reading the tire/gvw sticker on the door earlier and completely missed the big white sticker with all the three digit RPO codes right at eye level when squatting down to read the GVW sticker.
        Duh.
          The earlier 4th gen F-bodies have the RPO codes listed on the door and glovebox. Later models like the 98-02 only have the codes on the door.
          '99 Camaro
          '04 Saab 9-3 Aero
          '90 Audi Coupe Quattro
