Alarm Problem: Once I hit lock button 5 secs later it goes off - FirebirdV6.com/CamaroV6.com Message Board
  • Alarm Problem: Once I hit lock button 5 secs later it goes off
    My alarm on my '00 Camaro goes off about 5 seconds after I hit the lock button on my keyless entry pad. What all could be wrong with it?
    My horn also doesn't work anymore either so it doesn't sound but the lights flash when the alarm goes off. Horn also doesn't work when you push the center of the steering wheel.
    Everything worked fine about a month ago.
    Re: Alarm Problem: Once I hit lock button 5 secs later it goes off
    stock alarm or like a viper system with the car sensativety alarm?
      there is a shock sensor in the back of your car near the spare tire
      unplug it
      see if that solves the problem
        What he said^^
        If that solves the problem, take the sensor out of the car and dry it out real good, a few days or so. Then put it in a plastic bag or something and stick it back in. I just covered mine in saran wrap and it solved the problem. The problem was that the weatherstripping on the hatch was leaking water into the quarter panel, right on to the shock sensor. It filled up with water and shorted the circuit.
        This of course is assuming that it's raining where you are currently. Otherwise you might have a bad shock sensor, or if unplugging it doesn't work, you may have a bad sensor in either door or the hatch telling the car it's closed.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          Thanks guys I'll try that and yeah its been raining all day and supposed to for the next few
            So I unplugged the alarm in the rear a few days ago but haven't plugged it back in yet. I was looking under the spare tire and there was water down there so I think that's what caused it for sure, if it dries out fully will it be ok or is it wise to find a used one and replace it?
              My Hptuners stop working
              Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
              13 hours ago
            • Money pit
              Zzp cams
              by Money pit
              Has anyone used zzp gt1 cam if so is it worth the money and time
              2 days ago
            • thatpewterfirebird
              2001 3800 s2 firebird
              by thatpewterfirebird
              4 days ago
            • Turbo 3800 camaro
              Where are the videos?
              by Turbo 3800 camaro
              6 days ago
              New Chevele
              Just saw it on Facebook, looks awesome. The front and rear nice looking....
