firebird headlight module - FirebirdV6.com/CamaroV6.com Message Board
  • firebird headlight module
    so ive had all sorts of issues with the headlights, asked on a few sites and get **** for an answer.
    new passenger motor put in and theyre not working right still. so im going to try and change the headlight module or whatever the hell its call out and see if that works. i have no idea where its at though.
    Follow me!
    Or this
    Re: firebird headlight module
    It is located in the engine compartment, front left corner near the fusebox.
    On 93-97 it is mounted to the top of the air inlet tube before the filter. On 98+ it is as shown in the picture below.
      well **** me lol. i should have known it'd be right under my goddamned nose. i remember even looking at that and was like wtf is this for.
      Follow me!
      Or this
        Glad I could hep out. Hopefully changing that solves your problem.
          i hope so, im getting tired of messing with them
          Follow me!
          Or this
            What is the issue? I was able to fix mine with a used headlight motor. What is your's doing?
              well, the passenger side went nuts about a month ago, got so hot that the damn thing melted the knob on top of the motor, so when that happened, the drivers side one stopped working, i know that when one goes out the other will do all sorts of crazy shiz so i chalked it up to that. well, i replaced the passenger side with a new one, when i plug it in it seems to have a mind of its own, it'll go up and down whenever the hell it wants to, the drivers side one still doesnt do anything though. i thought maybe that motor was bad but i dont think thats the problem.
              here's the odd thing though, when the passenger one went, i hadnt used them all day and probably been 2 weeks or so prior to that. once its dark out im usually in for the night now so its rare that i go out at night. if i do i just take the wifes car anyways. the morning it happened, i stopped to get gas on the way to work, got my gas and everythign was fine, but by the time i got to work something went crazy in there because i pulled up to park, notice smoke rolling out from under the hood like crazy and all sorts of crazy noise, first thing im thinking is i done blew the motor or something lol, so i pop the hood and realize its the headlight motor going nuts.
              Follow me!
              Or this
                That is strange. Module sounds like a good place to start. Hopefully that solves the mystery.
                  man i hope so, its starting to get darker earlier so its going to be a pain lol.
                  Follow me!
                  Or this
                    the module senses a high load on the motor and cuts the power, it sounds like it's not doing that anymore. Replacing the module should fix your problems, if you keep using it with the new motor you will be buying another.
                    -Brad
                    2000 V-Star Custom 1100
                    :rock:
                      yeah that sounds about right then. i was going to mess with it today but i wound up getting a chance to catch up on a few weeks of sleep instead lol. was raining anyways so eff it. hopefully tommorrow i can get to it after work.
                      Follow me!
                      Or this
