Tail light full of water - FirebirdV6.com/CamaroV6.com Message Board
  • Tail light full of water
    Anyone ever had a problem with water in the left rear tail light on an 00'
    water is getting into mine some how.
    Re: Tail light full of water
    Check to make sure all the bulbs are in all the way and tight. Also maybe try using some grease around the holes where the sockets go into the lens. If it still leaks, check along the corners and plastic lining for any cracks.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      mine got so bad i had to drill a small hole in the bottom of it
      2001 Camaro 3.8 A4
      1991 3000GT VR4
      2001 Mitsubishi Eclipse GS
        the rubber gaskets where the bulb go in are probably bad.. i would do what pace suggested and put some grease around it
          drilled some holes in mine as well also did my front corners lights
          1998 Chevy Camaro 3.8
          1997 Chevy Camaro Z28 - SOLD 7-23-2011
          1996 Chevy Camaro Z28
          2001 Pontiac Firebird Formula
            firebird taillight?
            not much you can do, try sealing it and drilling some holes. Common problem on allot of drivers side tails on firebirds. Bad mold from the factory or something.
              Maybe try to seal with some silicone. Works on everything.
              Leonard
              www.fquick.com/96V6Junkie
                Thanks guys, just found the problem the other day, one of the sections of the light has expanded outward.
                  My Hptuners stop working
                  Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                  13 hours ago
                • Money pit
                  Zzp cams
                  by Money pit
                  Has anyone used zzp gt1 cam if so is it worth the money and time
                  2 days ago
                • thatpewterfirebird
                  2001 3800 s2 firebird
                  by thatpewterfirebird
                  4 days ago
                • Turbo 3800 camaro
                  Where are the videos?
                  by Turbo 3800 camaro
                  Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
                  6 days ago
                  New Chevele
                  Just saw it on Facebook, looks awesome. The front and rear nice looking....
