Lights Flickering - FirebirdV6.com/CamaroV6.com Message Board
Lights Flickering
  • Lights Flickering
    When I open my car with the key the lights start to flicker like the alarm is going off. When I bought my car, the owner told me the horn wasn't hooked up which I can assume is because of this reason. I can start the car up and it starts right up as well as the flickering stops.
    What can be causing this?
    Re: Lights Flickering
    more than likely your lights flickering issue is coming from the massive amounts of 684hp cranking off your stock battery.
    *Matt
      Thanks for the help at answering my question.
      To everyone else, someone told me that GM had problems with their factory alarms and this may be causing it. Is this true?
        bump..
