bcm solder points
Re: bcm solder points
yes those are the soldering joints...not sure what the motorola thing is...I dont have one...could be an aftermarket thing?
add some solder make sure they are soldered real good. i spent about 20 minutes on mine makeing sure i added enough solder and they the solder was clean.3M MAFIA
________
| Dynomax Catback | Auburn Posi | 3:42s | B&M Ripper | DIY CAI | PVC Mod |
Next on the list: GT2 Cam| 105# Springs |Headwork| Headers |
you can just heat it up...maybe add a touch of solder...but heating it up so that it melts then rehardens is probably enough...I added a little because I didnt wanna have to do it twice if it wasnt enough...all you are really fixing is the fact that somewhere in those joints there is cracks that is causeing the connection to be broken...
Originally posted by LETZRIDE View Postyou can just heat it up...maybe add a touch of solder...but heating it up so that it melts then rehardens is probably enough...I added a little because I didnt wanna have to do it twice if it wasnt enough...all you are really fixing is the fact that somewhere in those joints there is cracks that is causeing the connection to be broken...
i see people globbing solder everywhere, and getting mad because what they did didnt work
and a note, add the solder to the board, and not the pencil
Originally posted by cam98aro View Postyes, i agree, just heat it up with the solder pencil until it melts then QUICKLY remove the pencil, and you will get a perfect joint.
yup...
Well I followed the directions to a "T" and also read the thread over at LSI forums and no luck. Still no power locks, lights on the mirror or rear defrost. I put my gun right on all points until the solder melted.
Does anyone know what each of those relays are?
One of them keeps clicking every 15 seconds.
