LED taillight bulbs - FirebirdV6.com/CamaroV6.com Message Board
LED taillight bulbs
  • #16
    Re: LED taillight bulbs
    Originally posted by FirebirdGT View Post
    Brightness is an attribute of visual perception in which a source appears to be radiating or reflecting light. In other words, brightness is the perception elicited by the luminance of a visual target. This is a subjective attribute/property of an object being observed.
    Lumens DO NOT measure brightness.
    Absolutely. But given the circumstances, luminous output is an at least relatively valid way of measuring the difference between light sources mounted in the exact same location relative to all reflectors in the tail lights.
    I believe the reason a 210 lumen LED array can perceptively outperform a 400 lumen incandescent bulb in our case is due to the nature of an LED light source. By this I mean the fact that even though there are 400 lumen coming out of the incandescent bulb, a portion of this is filtered out (blocked) when it passes through the tail light lens (the yellows and blues that make the light appear white), whereas the LEDs are emitting pure red, and under perfect circumstances, the lens should, in theory, not block any of the light emitted from the LEDs. In other words, if our incandescent bulb emitted pure red, as the LED does, it may measure an equal, or lesser luminous output, which in our case, would cause the LED to appear brighter.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
    • #17
      too me the LED's look like someone put christmas tree lights in their tail lights.
      • #18
        WTF are you talking about. Stock replacement bulbs, or the ebay ones?
        • #19
          wow really? i believe they're talking about replacing just the bulbs---it wouldn't change how they look on the outside.
          and even full LED replacement taillights aren't bad---look at schlotzky's led conversion, it's damn sexy.
          pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
          gone in body, but not in spirit
          • #20
            Pics of my conversion for the heck of it.
            running:
            brakes:
