passanger window problems - FirebirdV6.com/CamaroV6.com Message Board
  • passanger window problems
    my passanger window will not go down, i switch the the motor since i had replaces it and was still under warranty adn nothing it will only go up. then i swapped the button and same thing it will only go up but it wont go down. what do you guys think wrongs. it was working fine the whole morning and in the afternoon it started acting up. my driver window works fine it goes up and down
    Re: passanger window problems
    Anybody??? Anyone know what can cause this
      Which switch did you replace? The pass or driver? I'm not sure how they are wired but I feel like when I installed the autotrix window kit I just spliced in to two wires that went to the passenger switch. Maybe the driver switch goes through the passenger switch? Most likely it's something to do with the wire connections over in your passenger door, either at the switch or motor connector end.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        i replace the the passanger switch. ive checked the connection adn they seem fine no cables are torn or anything the connection to the motor is fine also. ive crakced my head tryign to figuere it out the only thing i havent done is replace the drive side switch to see if that can be the culprit.
          Sorry to hijack; but did you like that kit? I've thought about ordering it several times.
          And to the OP, my guess would be maybe a short in a wire somewhere if you have a brand new switch...
            Check the switch on the driver side, power run through the driver side switch and then to the pass side
              Check and see if there's any power on that wire. That would be my best guess on.
                turned out be that driver side switch was shot i got a new replacement today and it worked lol. i was about to burn the car down i fix one thing and another breaks lol
                  Glad you figured it out. I had the right idea but my switches backwards. And to dgreet, yeah, I love the autotricks kit, it gives the switch a satisfying click when activated and works much faster and smoother than stock. I'd recommend replacing the motor at the same time, even though the kit did wonders for my factory motor, it eventually made it overheat.
