I went through my carwash at work and it destroyed my antenea, has anyone put a power antenea in a camaro before? will it fit? is it worth it?
antenea
Re: antenea
Love the fin, you got a write up or thread you started about it? I've been wanting to do something different with mine other than just chopping it in half.Let's flip a coin. Heads I get tail, Tails I get head.
Re: antenea
http://forum.camarov6.com/showthread...ight=shark+fin
Didn't really make an install thread. Just fiberglassed the old antenna whole up and repainted the area, drilled a hole in the roof and ran wires to the stock subwoofer power and tapped into the stock antenna wires. I may have a couple progress pics if you want them.
Re: antenea
Yeah man if you don't mind emailing them to me or just post them up. I found a couple on ebay and they're reasonable, not sure about my body or fiberglass work though. Any tips or suggestions there? If I recall your the rattle can king with the body work you've done on your car.Let's flip a coin. Heads I get tail, Tails I get head.
Re: antenea
They came black, but the actual lens was 100% clear. I had them professionally tinted, but niteshades would work as well. The body shop just threw it in for free so I figured why not.
Yeah, the reception is decent. Not as good, but not bad I wouldn't say. And it should be rigid enough to make it through any car washes. You can also buy stubby antennas that are usually rubber coated and a bit thicker.
Re: antenea
Ya the stock antenea in my opinion isnt that great. Its o high, and does not go with the lines in the car. So i went to checker and picked up a $3 smaller rubber antenea i think it looks good. What you think?
But then i cant really put mine threw car washes cause the convertible so:rolleyes:
