So i put in 24 cm L.E.D strips in the hood scoops. Here's how i did it.
FIRST- Drill out the middle hood scoops so that you can fit like a quarter of a inch in them.
SECOND- Drill out the inlay part of the scoop with like twenty holes.
THIRD- Fit the led strip in with apoxy in so it stays.
Then run the power wire and ground threw the heat shield part. To A wire cover that you'll put in and hook it up to a switch.
Check it out
Check it out
