3rd brake light works. main brake lights do not work - FirebirdV6.com/CamaroV6.com Message Board
  • 3rd brake light works. main brake lights do not work
    looking through the wireing schematics...i see that my brake pedal switch works just fine since my third brake light (high center mounted) works just fine.. however, my two main brake lights in the back do not work.
    Going back through the schematics, I see that my rear stop lights go through the turn/hazard switch assembly. My hazard switch works.. my turn signals work just fine, my wipers and high beams turn on just fine.. brake lights.. no go.
    i've swapped out all new bulbs and sockets.. still same problem.
    I don't have a haynes manual, can anyone give details on how to remove and install a new turn/hazard switch assembly?
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    Re: 3rd brake light works. main brake lights do not work
    Wow, havent seen you post in what seems like a few years tyler.
    What makes you think the turn signal / hazard switch is the cause of your problems?
    Kind of sounds like a bad ground to me... Also, did you check the fuse?
    *Matt
      http://tss.likeabigdog.com/
      This is for w body cars, but the general procedure should be the same
      • Manimal
        Coil springs
        by Manimal
        6 days ago
      • Manimal
        Newby here
        by Manimal
