Removing marker light housing.. why so difficult? - FirebirdV6.com/CamaroV6.com Message Board
  • Removing marker light housing.. why so difficult?
    Hey all,
    For some time now I have been without a right side turn signal. The hole that the bulb slides through at the top of the housing had a few cracks in it which allowed water to seep inside and short out the bulb. Today I had some time, so I removed the headlight so I could access the marker light housing. I removed the three tiny screws that held it in place, but the darn thing wouldn't come out. There wasn't enough clearance to just slide it out. After a few minutes I gave up and put silicon over the cracks, inserted a new bulb and fastened it back in. I also noticed that there is a large, flat piece of metal laying at the bottom of the housing. I guess it used to stick to the top of the inside of the housing? Also, is there an easier way to remove the marking light housing? I know some of you guys and gals have the clear or tinted housings which will eventually be one of my modifications. That way I know what to do when I get around to replacing them.
    Thanks, Joe
    Re: Removing marker light housing.. why so difficult?
    Never done the swap on a 98+, but I've always done it from below. I believe it's just 2 or 3 7mm screws. I never had any problems taking them out, from then iirc you just pull up and out.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      i did mine from the top, it was straight forward.. take the screws out, disconnect the bulbs, then just slide the marker light out the front
        When I replaced mine to clears I had to slide it over to one side then pull it out. Kinda a pain but just play around with it and you'll find a way to get it out.
        3M MAFIA
        ________
        | Dynomax Catback | Auburn Posi | 3:42s | B&M Ripper | DIY CAI | PVC Mod |
        Next on the list: GT2 Cam| 105# Springs |Headwork| Headers |
          Same here on my 96' just take them out from the bottom, then when putting the new ones in ,they kinda of click into the spot , if not they might be misallighned and have gaps.
