my ac system has been empty since the swap. Trying to get it charged today. I noticed when i was adding oil to the system the compressor clutch wasnt spinning. Is that normal ?
A/c Compressor clutch not spinning ? system is empty
Re: A/c Compressor clutch not spinning ? system is empty
Originally posted by Tom Rs View Postmy ac system has been empty since the swap. Trying to get it charged today. I noticed when i was adding oil to the system the compressor clutch wasnt spinning. Is that normal ?
You need to jump the low pressure cut off and force the compressor to run when charging it from empty.sigpic
you should put the oil in when the compressor is off the car, never use the stuff from the can.
when you are putting more freon in, the pressure in the can will be enough for the compressor to kick in.
My Dad and I just used the kit at Nappa with the gauge and freon and just put the A/C on Max and I put my manual fan switch on high and it took about 2.5 cans , the stuff i used had oil already in the can. I'll be doing this again at the end of summer when I replace my A/C condensor. If its humid or not hot out it might be hard to get the freon to go in all the way. I had a temp gauge on the middle vent and it got to like 30-40 degrees.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Tom Rs View Postthanks for the info. how do you jump the switch ?Last edited by bigbrian442; 07-06-2010, 07:27 AM.sigpic
