Ghost in the Machine? Radio & horn operate erratically. - FirebirdV6.com/CamaroV6.com Message Board
  • Ghost in the Machine? Radio & horn operate erratically.
    Hello!
    I have a 1995 Firebird Convertible, 3.8 Ltr., that has the radio/CD controls on the steering wheel. I bought the car when it had 95,000 miles on it and it now has 180,000 miles on it. Over the years some strange problems have started popping up.
    The radio controls on the steering wheel worked fine when I first bought the car in 2004. Gradually, they stopped working at all. I didn’t mind enough to pay to have it fixed as long as I could still adjust the radio with the manual controls in the dash.
    But then, a few years ago the radio started increasing the volume by itself when I turned corners. It would get so loud it was painful. The frequency of the volume problem started to diminish only to be replaced by a new one: the radio started changing channels by itself!
    Whenever I would get in and start the car, the radio would scan (without ME touching the controls) by itself and usually land on a station I can’t stand. What’s worse, it refused to allow me to change the station back by hitting the pre-set buttons until the car had run for at least a minute or two. (???)
    Over the past couple of years, the radio has started randomly changing stations WHILE I’M DRIVING. This is truly annoying – it always seems to do it just as an important piece of information is being announced!
    But then, over the last couple of weeks ANOTHER phenomenon started happening: the horn started blowing by itself! It happened when the car had been sitting parked in the direct 94-degree hot Florida summer sun. To make the horn shut up, I had to open the door and pound on the padded part of the steering wheel and turn it a few degrees. I finally connected the dots and realized that it only seemed to happen when the car was HOT inside. (Could it be that something is expanding with the heat and allowing the contacts to touch?)
    Well, the final straw was reached a couple of days ago (and is the main reason why I’m posting this thread). The horn started blowing randomly AS I WAS DRIVING! This was annoying to say the least, but then it became downright dangerous as it almost sparked road rage from the drivers in front of me – the last thing I want to do is take a bullet from some crackhead who thinks I’m P.O’d. at him!!!
    So, I pulled the horn fuse and now I’m driving around without a horn, praying that I don’t need it to alert a pet, a child or some idiot to get out of the way before they get run over! I suspect that all of these problems probably stem from the same root cause.
    QUESTIONS: Does anybody out there have any information on these ghost-like problems? Is there something in the steering column that is worn out? If so, is it easily replaced as a do-it-yourself project? Or should you let a mechanic trained in this area do it since you’d be messing around the air bag? Are parts easily available? Expensive? Where would you find the parts; “dealer only?”
    Surely I’m not the first Firebird/Camero V6 owner to experience this “Ghost in the Machine?!?”
    Thanks in advance for your help!
    Reefshark
    Reefshark
    Re: Ghost in the Machine? Radio & horn operate erratically.
    Originally posted by Reefshark View Post
    Camero
    I was gonna help you, until I read that. Really dude, really?
      Re: Ghost in the Machine? Radio &amp; horn operate erratically.
      I didn't think they made Cameros anymore... :P But really, that sounds like some major electrical problem. Probably a bad ground. I have undone some grounds in my car to determine where I should ground my HID's, and when I undid some factory grounds, the highbeams came on all by themselves, and was just acting weird. Check the grounds to the left and right of the airbox.
      #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
        Read WHAT? (Really WHAT?) Dude, please be specific. Really, dude, really.
        Reefshark
          Does it put on love songs when youre with a girl? or action ones when you're driving aggressively?
          Wait, Is that a V6 or V8?
            I thought this website had serious Firebird & Camero enthusiasts as patrons. Apparently, I was wrong. Why can't you jokesters just admit you don't know the answer?
            Oh yeah; when the car feels that I'm being dissed, it starts playing the music from Jaws.....duh dunt, duh dunt, duh dunt, duh dunt...........
            Reefshark
            Reefshark
              Stop spelling camero so right, the answer was already mentioned having to do with possible faulty ground.
                Herby?
                *Matt
                  Is your firebird... Fully Loaded?
