I need to know how to unhook the wire harness from the driver side firewall. It has two clips i pulled back but it wouldent split. Any input would be great.
It doesn't split you have remove all the connections from the steering column as well as others. I suggest you trace all the wires if you want to remove the wiring. Then pull it out.
