Since I did my conversion my water temperature gauge and Oil pressure gauge don't read right at all. But on Hptuners they read correctly. If I was to change my cluster could that fix the issue?
Oil & Water temp Gauges
Re: Oil & Water temp Gauges
Originally posted by insaneABOT View PostSince I did my conversion my water temperature gauge and Oil pressure gauge don't read right at all. But on Hptuners they read correctly. If I was to change my cluster could that fix the issue?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I don't blame, you but 1 gauge can do water and temp they can do 2 Acesssories, and then you can check all the other stuff as well just by hitting the 2 buttons. Well worth it , for me anyways. S.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
