Horn weak - FirebirdV6.com/CamaroV6.com Message Board
Horn weak
  • Horn weak
    2000 Camaro....OEM horn went out. I spent $60 on "bad boy horn"...installed worked fine....then after a year it could barely be heard.....sent it back to mfg. Installed
    a small alarm horn....worked fine for 2 weeks then it could barely be heard....same thing. Checked wiring....all tight
    and all there. Anyone had this issue?
    Re: Horn weak
    Don't know my 2 96' horns are still fine , never replaced them before. Maybe look at how much they draw in amps and volts so they aren't over stressed.
      Re: Horn weak
      Double check your grounds, clean them very good to bare metal.
      Also, is it mounted in a location that is getting wet / road debrit ?
      *Matt
        Re: Horn weak
        Did it. Car in Florida, garage kept
          Re: Horn weak
          I had this problem when I first got my Camaro. There are actually two horns in there (on mine anyway)
          and one of them was bad, didn't work at all. The one that did work was a bit weak, too.
          So I replaced the bad one and cleaned all the connections. They work great now.
          I'm not sure if the 2000 is the same, but my '01 doesn't use the body ground. The ground comes from the connector / wiring harness.
          You may want to follow that ground wire back through the loom and make sure it has a clean connection.
          Another thought is that the horn relay may be bad. Although I would think it would either work or not work.
            Re: Horn weak
            Theres 2 horns stock on all F-bodies.
