Adding Cruise Control - FirebirdV6.com/CamaroV6.com Message Board
  • Adding Cruise Control
    My Camaro did not come with cruise. I would really like to add it (I do
    quite a bit of highway driving.) Anyone know what is involved with adding it on?
    (what parts I need, pcm reprogrammed, etc?)
    I would like it to look stock, if possible.
    Thanks.
    Re: Adding Cruise Control
    Get a brick. That's about the only way you're gonna make it work.
      Needless to say, that's not quite the answer I was looking for.
        It would be too hard to do for what it is worth, taping into the pcm harness, adding the box and running the cables.
          couldnt you just buy a stock with cruise control built in?
          Robby
          2001 Chevrolet Camaro 3.8 V6
          |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
          http://speed-bros.com/
            That would cover the switch... You'd still need a cruise module and some wiring work to get it to function. I don't have my haynes handy or else I'd see if I could post a schematic to work off.
            1996 Chevrolet Camaro
            1995 Buick Park Avenue Ultra
            --Appearance Moderator--
              Here's what Autozone has. Hope this helps (the schematic says 1999):
                Sure beats the old days when you had to glue magnets to your driveshaft. Anyone remember that?
                  Actually, that diagram doesn't seem like it would be too hard.
                    you'd also need a new turn signal lever, right?
                      Yup..
                        ScottS4050,
                        How did this work out for you? I'd like to do the same thing on my 99 camaro. Do you happen to know of any guides or reference material I could use for research?
