I've never removed the connectors from the relay box but they are basically all the same. There is a bent over tang that holds them in place. I use a very small flat screwdriver the kind you would use for eyeglass repairs. Insert the screwdriver from the top, push in the tang ( you will have to look to see which side it is on) and pull the wire out from the bottom.
2 days ago
