I've noticed that my (original) alternator's voltage regulator seems to be going out- on a full load (lights and accessories on), if the engine speed drops to around a hi-idle (~1000rpm) suddenly the lights will dim momentarily and the gauge will drop from a little over 14V to around 13V. It quickly corrects itself after a second or two.
So actually I got 2 questions here:
1) does this sound like the regulator's going out? It charges just fine, it's just this one little annoyance that's going on, and it's not even consistent- just does it once in a while...
2) The car, being a daily driver- I'd rather swap out the alternator myself rather than let someone else do it. Coupled with the fact that decent name-brand alternators (Beck-Arnley, AC Delco) cost upwards of $200 from the auto store I'm thinking of pulling mine and taking it in to a alternator/starter shop to have it rebuilt. Menawhile if I can find a working alternator in a junk yard to run in it's place (or take that in to have rebuilt instead) that'd be great. But what GM car(s) used the same alternator setup I have, in case I can't find a similar year Firebird/Camaro donor? This is on a 2001 Firebird V6.
Thanks, all!
David
Thanks, all!
David
