My car originally came with the monsoon sound system. Now the current setup is an aftermarket stereo then 6 speakers, 2 in the front doors, 2 back in the hatch area, and 2 in the backseat area. Only the front and the hatch speakers work b/c i dont have the factory amp in. Now here is my question, if I would put the factory monsoon stereo back in and the monsoon amp, would that make all 6 of my speakers work instead of the 4 that work with an aftermarket stereo.Or could I leave an aftermarket stereo in, run it to the monsoon amp then run it from the amp to the 6 aftermarket speakers. :tup: Ive been told that the monsoon sound sytem actually sounds pretty decent. Plus Id like to have all 6 of my speakers working. I have no idea what to do
Monsoon Questions
Re: Monsoon Questions
Short version- Monsoon blows.
Long version- Monsoon blows, therefore rewire in head unit power. Either replace the sail panel mids with some full range 6.5"s or keep those wired into the Monsoon. Otherwise, the entire amp/HU system from Monsoon is nothing but a static box.
http://forum.camarov6.com/showthread.php?t=104269
I explain it in a ton more detail there.
Originally posted by insidethreat07 View PostHow can I get the sail panel to work tho? They dont work with my current set up. Im not very good with stereo stuff if you cant tell lol
Replace the sail panel speakers with the stock 4 speaker system sail panel speakers and splice them into the wires going to the quarter panel speakers.
I have a Monsoon installed into a 4 speaker system, and then spliced in the rear quarter panel speakers. Total of 6 speakers. Works fine.
.Last edited by FirebirdGT; 10-22-2011, 11:46 PM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
^^ He's right. At lower volumes the Monsoon is good, sounds like it needs to. Also correct on the sail speakers. I modified mine to hold 6x9's and cut out the hatch speakers, then used the wires for those in the sails, and it sounds glorious.
Originally posted by Docta View Post^^ He's right. At lower volumes the Monsoon is good, sounds like it needs to. Also correct on the sail speakers. I modified mine to hold 6x9's and cut out the hatch speakers, then used the wires for those in the sails, and it sounds glorious.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
