led turn signal bulb problem - FirebirdV6.com/CamaroV6.com Message Board
  • led turn signal bulb problem
    i just upgraded to leds on my running/turn signals. now my turn signals flash real slowwwwwww... whats the fix for this? different type flasher ? add resisitor?
    Re: led turn signal bulb problem
    You could add a resistor, or just get an electronic flasher unit. They are like 8 bucks at autozone.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      http://www.camaroz28.com/forums/show....php?p=6736083
      scroll down a bit for pic
        thats a whole different problem but thanks anyway
          going to try a electronic flasher unit .... seems the problem most have with led upgrade is no flash or fast flash . i also failed to mention in 1st post the car also has sequential taillight modules ..
            I'm not sure how the electronic unit will react with the sequentials. From what I've read, sequential kits use hazard flashers for a slightly slower flash rate for the full sequential effect. I'm still confident that the electronic flasher will solve the mentioned problem, but I couldn't tell you whether it will disallow the full effect of the sequential tails or not.
            For you, a resistor might be a better bet.
            I believe the turn signal filament for a 3157 is right around 27 watts, so with P=IV and V=IR, R=V^2/P. Your resistor should be around 5-8 ohms with a power rating of at least 35W, probably closer to 50W. I would think you could find these at RadioShack or similar electronic stores. Wire it in parallel across the positive and negative wires of the turn signal leads.
              glad to say the electronic flasher did the trick...flashing speed is normal again
                i was just posting for the location of the relay, seeing how most people dont seem to know where it is.
