i just upgraded to leds on my running/turn signals. now my turn signals flash real slowwwwwww... whats the fix for this? different type flasher ? add resisitor?
led turn signal bulb problem
Re: led turn signal bulb problem
http://www.camaroz28.com/forums/show....php?p=6736083
scroll down a bit for pic
I'm not sure how the electronic unit will react with the sequentials. From what I've read, sequential kits use hazard flashers for a slightly slower flash rate for the full sequential effect. I'm still confident that the electronic flasher will solve the mentioned problem, but I couldn't tell you whether it will disallow the full effect of the sequential tails or not.
For you, a resistor might be a better bet.
I believe the turn signal filament for a 3157 is right around 27 watts, so with P=IV and V=IR, R=V^2/P. Your resistor should be around 5-8 ohms with a power rating of at least 35W, probably closer to 50W. I would think you could find these at RadioShack or similar electronic stores. Wire it in parallel across the positive and negative wires of the turn signal leads.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
